La165 crank no start
   / La165 crank no start #1
Zdoc
La165 & yth1542xp
So I picked up an la165 for free. Wouldn’t start and would pop fuses because of a ripped wire st the pro. Repaired wire and replaced fuse started and ran great but the front wheels were toed way out, I installed adjustable drag links to correct that. I mowed maybe 1/3 acre heard a pop and the front end was on the ground.inspected and found the front axle split. Started and ran fine to back put to my garage to install the new front axle. Removed the muffler to install the new front axle and now it won’t start. It cranked and backfired and now won’t start and the battery is dead. Of course charging the battery and my jump box which is dead to try to start tomorrow. The only thing related to the engine I removed was the muffler so I’m a little perplexed why it so difficult to start all the sudden. It always fired right up with choke then cut off choke and add throttle
Ripped wire to the pto
   / La165 crank no start #3
Face it,they only gave it to you because it's rebellious and they were tired of it's tantrums. 😁
Ha yeah but it started so nicely and ran great before. Trying to patiently wait another 16 hours to try and start again. Battery charging and jump box charging
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
CHAMPION 1 PERSON GAS EARTH AUGER (A51248)
CHAMPION 1 PERSON...
UNUSED RAYTREE RTSG30-30" STUMP GRINDER (A51248)
UNUSED RAYTREE...
2025 CFG Industrial STSD10 (A50123)
2025 CFG...
2018 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2018 KOMATSU...
UNUSED CFG INDUSTRIAL KKT(A)27 STAND ON SKID STEER (A51247)
UNUSED CFG...
