LA115
   / LA115 #1
leonz
Super Member
NE USA
JD LA115, WH 244, Troy Built Horse 8 HP
Just curious as to how many of you have the snow blade for the LA115?
I bought mine the other day to add a new tool to the stable as I wanted to
have something to do light grading with and it is not very heavy.
I have to tighen the trip spring on it to make it work better
but I will not be using it for plowing snow.
I really thought for $400.00 I would have been sold a stronger plow blade.
Is this blade used on the next series/higher horsepower JD units with larger frames too?
My dead wheel horse 244 hydro has a blade and frame that weighs half as much as
the plow and the LA115 together.
I know you get what you pay for.
Makes me wonder whether the 2305 would have been worth it but I hesitated in buying it when I
read that the aluminum rear axle had a habit of breaking.
I have to mount the casters on the snow blower/caster before the snow season comes and
have a pipe made to mount the beacon on it as I will need it for the two driveways.
   / LA115 #2
The issue you will have is with the wheels slipping. You will have to add some weight and chains to your tractor. I had found a like new used one for 100 bucks a few years back, but after reading about the tractor I have (LA120) I passed. The people's biggest issue was that there was no traction.
2021 Isuzu NRR Heil 9Yd Mini Rear Loader Garbage Truck (A50323)
2021 Isuzu NRR...
2017 Snapper Pro 48in Zero Turn Commercial Mower (A51691)
2017 Snapper Pro...
John Deere 5203 Tractor (RIDE AND DRIVE) (A50774)
John Deere 5203...
Mini Forks (A50322)
Mini Forks (A50322)
Category 3 Quick Hitch (A50514)
Category 3 Quick...
