leonz
Super Member
I recieved the replacement cable for the lift on my
LA115 and I replaced it yesterday before dark.
The repair went well and I am happy they have
changed the cable type to allow you to lubricate it.
Removing the rubber handlegrip was a bit time comsuming only because
I had to soak the handle in hot water to get it to loosen up.
I raised the snow blower up and locked it in the raised position and then
took the large mixing measuring bowl of very hot water and lifted it to
the point where the handlebar war immersed in the very hot water.
The rubber was heated sufficiently so that I could slide the handlegrip off
and slide the plastic cable lock on to the handle bar.
