LA1002 Hose mix up
   / LA1002 Hose mix up #1
esardo22
Buxton Maine
various
I changed three of the hoses on my LA 1002 loader on a M6800. Now the arms will only go up 1 foot and they stop and the bucket will roll in and out about an inch and stop?? Mixed up hoses? If I switch the blue and white lines, it will operate completely but backwards!! HELP!
   / LA1002 Hose mix up #2
Your situation is easy to fix by using common sense, and here's how.
If your cyl hose are still connected to the two tees, disconnect the other end of the hoses from the loader valve.
Now, pull the FEL lever back just a little. Fluid will flow from one of the work ports. That hose goes to the base end of the lift cyl.
Push on the lever and fluid will flow out one of the work ports. That hose goes to the rod end of the lift cyl.
Push lever to the right, and fluid will flow from one of the work ports. That is tilt down/bucket dump and regen.
There is only one work port left, and that goes to the rod side of the bucket cyl tilt up.
Look at the bottom of this PDF, shows a loader. See if it makes sense.
http://www.surpluscenter.com/_MoreSpecs/i9-7401.pdf
You were right, just hose screw up. B/R work the bucket and W/Y the lift. Thanks for the help.
Brent 420 Grain Cart (A55301)
Brent 420 Grain...
2017 Caterpillar D5 K2 LGP (A55218)
2017 Caterpillar...
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2017 Ford F-650 Stakebody Flatbed Truck (A55788)
2017 Ford F-650...
