LA 481 Relief Valve Pressure Adjustment
   / LA 481 Relief Valve Pressure Adjustment #1
john_bud
Super Member
Hi,
I need to know the procedure and specs to set the relief valve on the LA481 Loader on my L3410. It no longer will pick up what it used to and I suspect that the pressure sensing spring is starting to take a set after 6 years.
jb
   / LA 481 Relief Valve Pressure Adjustment #2
I am about to look into upping the loader relief on an '85 L2550.
I suspect the spring is "tired" or broken. This is the BF400G loader.
I do not know the spec for your loader, but I suspect it is about 2200psi.
You need to check that at the cylinders first. A metric fitting
for your gauge is reqd. Then you can replace the spring or add shims.
IMO, the Kub loaders should be able to handle 2500psi, as my JDs
do. The JD loaders I have are not built as stout. I do not know why
the Kubs are set so low. Check you pressure and report back.
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2018 HINO 195 16FT BOX TRUCK (A52576)
2018 HINO 195 16FT...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
(2) Drums of Car Wash Brush Soap (A51573)
(2) Drums of Car...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
