LA 301 loader relief valve
   / LA 301 loader relief valve #1
mrshoes
kubota b2100hst
Hi all,
Bought a B2100 recently that has a LA301 loader, It will not even lift the front end of the tractor off the ground or lift much of a load in the bucket so I think the relief valve is set to low.
the question is where is the relief valve physically located and is it adjustable?
Thanks,
Mr shoes
   / LA 301 loader relief valve #2
It is probably on the FEL valve, slose to the IN port.
If you show us a picture, we can tell you more.
Do you have a 3000 psi hyd gage?
Do you know how to set the relief pressure.
Do you know what the relief psi should be?
   / LA 301 loader relief valve #3
I think the B2100 also has a system relief valve on the transmission case. It can be tricky to figure out which one is letting go first. If you find that adjusting the loader valve relief doesn't help, then the system valve may be the issue. I think the system valve is adjusted with shims.
1990 LOAD KING BELLY DUMP (A53843)
1990 LOAD KING...
1981 AZTEC SKINNY NECK 31 FOOT FLATBED (A53843)
1981 AZTEC SKINNY...
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
stump grinder for mini skid steer (A53421)
stump grinder for...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
