LA 105, Choked while running, now wont start
   / LA 105, Choked while running, now wont start #1
titanfanman
John Deere LA 105
While mowing at full temp and throttle the nephew pushed the throttle lever up to full choke position, it immediately stopped running and will not start. acts like it is not getting any gas. however gas mist appears to be coming out of the air intake hole beside the air filter. Any thoughts or advice would be greatly appreciated. Its a John Deere LA 105 with about 85 hours on it. Thanks again
   / LA 105, Choked while running, now wont start #2
A new spark plug might just make it run and if the air filter has 85 hours replace it too.
   / LA 105, Choked while running, now wont start #3
If you're seeing "gas mist" around the air cleaner... that would likely indicate a flooded engine - and a "wet" spark plug!
As SandBurRanch indicated a new spark plug and a new air cleaner should do wonders for getting things going again.
AKfish
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
