L6060 will not start
   / L6060 will not start #1
WVUFAN
S.C., WV
Kubota B3000cab
Hello, long time lurker, first time poster. I have a brand new L6060 with cab with 3 hours on it. It was delivered this past Friday and driven around the 吐arm then put to bed in the garage. Plugged in the engine block heater before lights out. Next morning went to start 派er up and nothing, zero, zilch! The welcome screen comes up and shows error code 20 and CAN(engine) NG. I have been in talks with my dealer Barlow Equipment and per their suggestions tried charging the battery, running a new ground wire from the upgraded alternator to the frame and checking fuses in the cab. I have the service manual which I have been reading this past weekend, along with multiple forum searches. This is my third Kubota and I知 proud to say they have served me well in the past. Sorry for the long winded post.
   / L6060 will not start #2
I believe that is a communication issue from the ECU. There is a method to clear codes, but it will not be successful if there is a concurrent fault.
Personally, being a brand new machine I would let the dealer fix the problem rather than offer up wild guesses and procedures.
   / L6060 will not start #3
Hello, long time lurker, first time poster. I have a brand new L6060 with cab with 3 hours on it. It was delivered this past Friday and driven around the �arm then put to bed in the garage. Plugged in the engine block heater before lights out. Next morning went to start 派er up and nothing, zero, zilch! The welcome screen comes up and shows error code 20 and CAN(engine) NG. I have been in talks with my dealer Barlow Equipment and per their suggestions tried charging the battery, running a new ground wire from the upgraded alternator to the frame and checking fuses in the cab. I have the service manual which I have been reading this past weekend, along with multiple forum searches. This is my third Kubota and I知 proud to say they have served me well in the past. Sorry for the long winded post.
Your tractor is under warranty.
Call your dealer had have them repair it.
SDT
   / L6060 will not start #4
SDT
Same post on OTT. Same answer... call the dealer. (I do get a chuckle out of people posting the same question on different forums wanting a different answer I guess)....duh
   / L6060 will not start #5
Different answer...
Trade it in on one that will start! :D
   / L6060 will not start #6
<snip>Next morning went to start 派er up and nothing, zero, zilch! The welcome screen comes up and shows error code 20 and CAN(engine) NG. I have been in talks with my dealer Barlow Equipment <snip>
Reads like a problem with the tractor being too smart.
Are you sure it's not something simple like it won't start without seat presence, the PTO selector moved or the brakes not set?
And for all the
Barlows is in Kentucky, the OP indicates he's in S.C. West Virginia. And this has been a holiday weekend.
   / L6060 will not start #7
Try disconnecting the negative battery terminal, then reconnecting it. This may reboot the computer in the tractor and clear the code. It may start then.
Barlow’s will be picking up the tractor later this week. Fingers crossed for a quick repair.
   / L6060 will not start #9
And for all the
Don't matter a bit. It's NEW so let them deal with it. One of the pitfalls about buying just on price from a not local dealer, something I NEVER do. Sure, under the Kubota warranty program, you can get a local dealer to fix it. Problem is, if not the selling dealer, you go to the bottom of the 'fix' list or at least with 99% of dealers. Glad my local dealer is in the 1%.
How it works and why I always buy local with anything motorized.
Don't care if Barlow's is in China, it's their problem.
   / L6060 will not start #10
I've always bought local and never had a moments problem with the local dealer. What might be a little extra cost with the local dealership is more than compensated by having it fixed - right pronto. A whole lot less gut aches also.
ITEMS ADDED DAILY (A49251)
ITEMS ADDED DAILY...
2023 MAC 42FT PNEUMATIC TRAILER (A45678)
2023 MAC 42FT...
2008 TROXELL KILL TRAILER (A48992)
2008 TROXELL KILL...
Fort DMD 2050 Disc mower (A49251)
Fort DMD 2050 Disc...
8 Titan Bush Hog, 3pt hitch, PTO  (A47371)
8 Titan Bush Hog...
2001 International 4700 Aircraft Fuel Truck (A46683)
2001 International...
