Hilbilly
Veteran Member
Ever since I got the L6060 I've noticed it was hard starting in cold weather, even after the block heater has been plugged in all night. Last year I called the dealer and told him of the issue and he said to use a multi meter and test across the plug terminals to see if there was resistance and there was. So this winter the same old problem again. This time I plugged in the block heater and put my finger on the part of the heater that sticks out of the block. It was so hot it almost burnt my fingers. However it is still hard to start. I then took a temperature reading of the engine coolant, using the intellipanel, and it indicated the coolant was 26*C before I started the engine. This morning at -26*C the tractor was hard to start and even stalled after the first attempt. The second attempt was successful but both times the glow plugs were on for a very long time before I started the engine. Then it took forever for the cab heater to start producing heat and it took a very long time before the engine temp gauge moved. The engine runs rough for a while and eventually settles down but this is so different from all the other diesel engines I have owned and still own. They all start very easy after being plugged in and it does not take long for them to produce heat. Something seems wrong with this setup.
Any ideas?
Any ideas?
