BurningtreeFarm
- Joined
- Feb 17, 2002
- Messages
- 21
I have a L5450 bought used it has 1714 hrs 120 hrs which I have run the tractor, after rereading the operators manual again I came across a little paragraph telling to not ever run the tractor with the pto clutch control lever in the disengaged position as premature wear will result on the clutch plate and thrust bearing. You have to have this disengaged to start the tractor and I never thought to engage it after the tractor started so needless to say for the last 120 or so hrs its been running with this in the disengaged position, any thoughts on the amount if any premature wear ive created?
Also the front and rear arms that the linkage runs between are bent this must have happened before I got it the rear arm is removable and so no problems there there straightening the other lever goes directly to the main clutch housing any thoughts on how to straighten this, they are bent enough to cause this linkage to run into other parts . Any thoughts and ideas are greatly appreciated, Tim
