L5240 with backhoe?
   / L5240 with backhoe? #1
C4Ranch
Veteran Member
Eastland Co, Texas
Kubota L5240 HSTC
Just curious if anyone has a backhoe on a GL and if you have pics of subframe and plumbing?
Do you have to remove 3pt arms to hook up and is it a pain?
TIA!
   / L5240 with backhoe? #2
My dad has a BushHog brand (with subframe) and it has a PTO driven pump.
He does have to remove the 3pt arms, and it is a pain. It's obviously still well worth it.
It is a GL, but it's a 10 series. L3710.
   / L5240 with backhoe? #3
Mine's also a 10 series, but here are some pics of the subframe in case they are of any help. This hoe runs off PTO pump and is not plumbed into the tractor's hydraulics. 3 pt. arms come off for the backhoe, but I've never regarded it as a nuisance. Just takes a few minutes on or off.
View attachment 450644View attachment 450645
   / L5240 with backhoe? #4
I have an L39 which is designed as a loader backhoe tractor and you still have to remove the three point arms for the hoe. Taking the hoe on/off is quite simple. It takes longer dealing the three point arms. Not that is difficult or a pain. Maybe just a little tedious. You have to remove a couple of bolts that hold the pins for the arms. I have anti-seize on the pins so I try to handle them with a rag so I don't get the anti-seize all over my fingers but somehow it still happens. You have to reach back in by the tires to get to the pins for the stabilizers. Again, nothing that is really a pain.
   / L5240 with backhoe? #5
Waxman has a 3240 with backhoe. You might check his posts or pm him for info on his subframe.
   / L5240 with backhoe? #6
I have a kubota l3240 cab hst-3 with bh92 backhoe yes 3pt needs to come off in order to put backhoe on and it's pretty quick taking on and off the backhoe once the 3pt hitch is off
Thanks.. I apparently don't have a HSTC-3 so not sure if woods makes a subframe for mine.. Still checking.
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
3in Poly Pipe (A49461)
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
2015 FORD F350 SERVICE TRUCK (A51222)
2015 FORD F350...
