L5240 cabin filter
   / L5240 cabin filter #1
mikeg135
Does anyone know the part number for the cabin filter for a L5240?
Thanks for the replies. I just picked up the tractor over the weekend so a cab is now to me.
I found the owners manual and it appears the is an inner filter and outer. Looking at those links each of you sent throat looks like the outer filter.
   / L5240 cabin filter #5
You asked for a cabin filter and there is only one that I know of. It is accessed from the outside rear of the cab. The air filter for the engine is under the hood and consists of an inner and outer filter.
Do you know if your tractor is a L5240 or L5240-3?
Here's the outer for a L5240-3. Kubota: ASSY ELEMENT, OUTER, Part # TD270-93230 Kubota: ASSY ELEMENT, OUTER, Part # TD27-9323
Inner for L5240-3: Kubota: ELEMENT, INNER A, Part # TD270-93220, Kubota: ELEMENT, INNER A, Part # TD27-9322
My owners manual mentions removing the re-circulation screen on inside of the cab and cleaning an inner filter in addition to the filter on the outside of the cab. I have removed and knocked out the dust on the outside cab filter, but my tractor did not have an inner filter behind the re-circulation screen on the inside of the cab.
   / L5240 cabin filter #7
Mikeg135,
Checked the drawings for the cab and they only show the one cabin filter referenced earlier. If there is another cabin filter, I don't know where it is or the part number. Good luck and enjoy your new tractor!
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A51039)
2000 John Deere...
TAKEUCHI TL8R2 SKID STEER (A51242)
TAKEUCHI TL8R2...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A51039)
2022 Gravely...
2006 TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
2006 TRAIL MASTER...
2020 KUBOTA RTV...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
