L5030HST & Michelin Tires
Status
Not open for further replies.
   / L5030HST & Michelin Tires #1
mnhgolf
The forums on this web site have helped me considerably in determining which new tractor I am going to purchase. I appreciate each of you for the invaluable information you share. I, like many others will be purchasing a new L5030HST-F. The only options I plan to purchase are front end weights and I will have the tires loaded with antifreeze or calcium chloride. I will use the tractor for finish mowing my 5 acre yard with a heavy duty 6 foot mower and box grading the steep 1/4 mile gravel road (20% to 30% grade in some places) to my house with a 5 foot box grader. If it weren't for the steep road, I could get by with something much smaller than the 5030. I will try to purchase the tractor with out wheels and tires so that I can install Michelin XM-108 R1W tires with the appropriate wheels. It appears this tire is the best radial tire option for traction, ride, soil compaction, longevity and less visible yard damage than a typical R1 agricultural tire. My questions are:
Advantages of antifreeze vs calcium chloride filled tires?
Which Michelin XM-108 tire sizes and corresponding wheel sizes (smallest to largest - front and rear) will fit this tractor and maintain the transfer case mechanical ratio of 1.564 with a +5% to 0% lead (This specification was posted by another member)? I realize this is probably a question for Kubota and/or Michelin, but I thought I would ask in case someone else had already been down this path.
http://www.michelinag.com/agx/en-US/products/product_detail_pages/XM108.jsp
Thanks again for your wealth of information!
Mike
I think I have found the answer to my Michelin tire question, but not the tire loading question:
Front Tires: Michelin XM27: 11LR16 TL 122AB with 8x16 or 10x16 wheels
Rear Tires: Michelin XM108: 540/65R24 TL with 14x24, 15x24 or 16x24 wheels
   / L5030HST & Michelin Tires #2
Duplicate thread. Closed.
Status
2007 PETERBILT 335 SERVICE/LUBE TRUCK (INOPERABLE (A50854)
2007 PETERBILT 335...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2008 CAT 287C (A50854)
PALLET OF TARPS, UMBRELLAS, AND PORTABLE SHADES (A50854)
PALLET OF TARPS...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
2024 Case IH Magnum 340AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
