Price Check L5030 & Options Pricing
   / L5030 & Options Pricing #1
FL_Cracker
Platinum Member
Palm City, FL & Blue Ridge, GA & Freedom, WY
Kubota L5030HST,R4 & Kubota RTV900R Utility Vehicle
Here's where I'm at with my deal right now. Wondering how the pricing looks to others.
L5030HST Kubota 50HP 4WD TRACTOR, R4 Tires $ 20,308.00
LA853 Kubota Front End Loader, 4-Way Joy Stick Controls $ 4,742.00
***Skid Steer Quick Coup. & HD Bucket Incl.
BH90 Kubota Backhoe Attachment, Sub Frame Mt. $ 7,200.00
L8305 1ST. Remote Hyd. Lines to 3PH $ 700.00
L8306/L8307 2nd. & 3rd. Remote Hyd. Lines to 3PH $ 750.00
Hyd. Lines to FEL, SS Std. Flatface Fittings $ 850.00
L8326 Top-N-Tilt Feature $ 615.00
Canopy Top, Aftermarket $ 375.00
Front & Rear Work Lights, 2 Ea $ 350.00
286 Woods HD 6' Bush Hog Rotary Cutter $ 1,900.00
RM990 Woods 7 1/2' Finish Mower, 4 Casters $ 3,500.00
MBX720 Woods HD 6' Box Blade $ 795.00
Maschio HD 6' Rotary Tiller $ 2,350.00
Fertilizer Spreader, 600 lb. $ 599.00
Tooth Bar for FEL Bucket $ 375.00
Total New Tractor Purchase $ 45,409.00
All in all it's about 20% off MSRP on the Tractor and 15% off on the Kubota options. Not sure about discount on implements.
Any help would be great...
Thanks,
   / L5030 & Options Pricing #2
<font color="blue"> "Wondering how the pricing looks to others."
</font>
Pricing looks good on the Kubota items. I have not priced the specific attachment items but they seem to be in line.
NICE SETUP!!!
   / L5030 & Options Pricing #3
Since mine is an L5030HSTC (cab), it's hard for me to compare prices. However, I'm certain that the Maschio tiller was under 2k. You'll love the tiller! I bought mine a while back after the JD dealer told me that his heavy duty JD tiller was made by Maschio. Although the color is slightly off (I had a JD tractor at the time), everything else was identical. /forums/images/graemlins/cool.gif It's a beast!
It appears that most all the issues I've had with my 5030 were traced back to when the dealer installed the T&T and extra rear remotes on mine. First off, the quick couplers on the rear leaked when in use and that was causing bleed off. Next, something in the valves was wrong and that caused a problem. Apparently not only was there something wrong in the valves, but the system got contaminated and ruined one of the lift cylinders on the front loader. /forums/images/graemlins/frown.gif After several trips back to the dealer, they finally got all right. I just mention this so perhaps you can sort of hint that they use care when installing the rear remotes and T&T system. My only complaint now is that the fuel tank is too small. Good luck!
Oh yeah, the Kubota front and rear work lights cost me around $135 each side (front side and back side) installed by my Kubota dealer. There is about 8 or 10 screws on the inside of the cab top to unscrew, then the top comes off. They can then install the lights in about 1/2 hour. The wiring is there from the factory and there is blanks on the top panel for the switches. On my last Kubota I had the factory Kubota radio with cassette and it was nice. This time, I put in my own stereo with a CD/MP3 player and Polk speakers. I like! /forums/images/graemlins/smile.gif
   / L5030 & Options Pricing #5
I'm leaving now to go up to around a couple hundred acres I own to bush hog in some trails for the RTV and Rhino. I'm taking two 5 gallon jerry cans of fuel with me. I'd have to see, but I'm guessing I only get around 5 hours or so on a tank when bush hogging or mowing.
   / L5030 & Options Pricing #6
Yesterday, I did 7 hours of FEL/box blade work and used nine gallons of diesel. The picture shows me preparing a site for my workshop.
Mowing does suck up the most diesel for me also.
   / L5030 & Options Pricing #7
On the L4630GST, tilling at full PTO speed the fuel light will come on in about four hours.
   / L5030 & Options Pricing #8
Well you must have really good judgement because your list has all the best items on it !! I don't know if the hydraulic piping options are in line or if some of that overlaps, but I can vouch for the Woods RM990 - the price is quite good for that and the BH286 - especially with the recent run-up in steel prices. It indicates your dealer is using a sharp pencil - Congats on a fabulous setup at an attractive price.
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
Land Honor Portable Screener (A50514)
Land Honor...
71050 (A49346)
71050 (A49346)
Willmar 4300 Wrangler Loader (A52128)
Willmar 4300...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
