Oil & Fuel L5030 hydraulic oil change causes difficult PTO engagement!!
   / L5030 hydraulic oil change causes difficult PTO engagement!! #1
jaywdeee
Ellenburg, New York
M5040, BX2370
Son in law's L5030 just got a UDT hydraulic oil change and not long after he found the PTO engagement to have become difficult. Not as before the change. He put in the correct amount of oil and double checked it. everything works OK except the engagement of at PTO. Any ideas out there as to why? Nothing else that I know of is different.
   / L5030 hydraulic oil change causes difficult PTO engagement!! #2
Please explain what you mean by "difficult". The lever won't move? The PTO doesn't turn?
- Jay
   / L5030 hydraulic oil change causes difficult PTO engagement!! #3
Which transmission?
The L5030 PTO clutch is hydraulic, the lever moves a cable hooked to lever of valve on side of transmission. Is the lever not moving or is oil not getting to clutch. There is also difference between HST and GST FST clutches, if not getting oil from regulator or charge pump system because of wrong filter or oil or loss of prime could also be problem.
David Kb7uns
   / L5030 hydraulic oil change causes difficult PTO engagement!! #4
Is there anything binding the cable system? Seems I've read other threads on here where the inner cable sticks or somehow binds in the casing, I thought people were lubricating it but I can't remember how or what with.
Thanks for the ideas to look for to help solve this problem. What would we do without this forum.
2013 Chrysler Town and Country Van (A50324)
2013 Chrysler Town...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
2016 FREIGHTLINER CASCADIA DAY CAB (A51222)
2016 FREIGHTLINER...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
