consultantfool
I am going to to the 600 hour service on my L48 this weekend. What hydraulic fluid can use other then the Kubota branded fluid?
Are you looking for a cheaper alternative to Kubota fluid? If not, just use Kubota stuff, although any major tractor brand oil will do (Deere, Case, New Holland, that sort of thing).
Don't go too cheap or you'll regret it. Sam's Club and Tractor Supply sell some hydraulic oil that doesn't work nearly as well in my experience. I've had to change a couple of tractors out within 5 hours. That is not at all economical. The old saying, "The cheapest consumer ends up paying the most." comes to mind.
In the past, I've successfully used New Holland Ambra and Case Hy-Tran. But there is not a big difference in price between them and Kubota oil.
New Holland-Ambra MASTERTRAN? ULTRACTION HYDRAULIC / TRANSMISSION OIL
I use Amsoil in the L48 but it is very expensive in the 10w-30 formula. And you'll need 15 gallons of the stuff.
I HAVE NOT CHANGED THE HYDRAULIC FLUID IN MY L39 IN OVER 1400 HOURS.
AT AROUND 400 HOURS I USED ROYAL PURPLE HYDRAULIC FLUID AND ITS BEEN THERE FOR ABOUT 8 YEARS.
DUE FOR A CHANGE & I'm USING IT AGAIN
I DO CHANGE FILTERS EVERY 400 HOURS OR SO.
I SNOW PLOW A LOT MORE THAN I LIKE TO.
STUFF IS GOOD IN COLD.
