Tires L4610 tires?
   / L4610 tires? #1
catskillsman
hi ppl.! can u put industrial tires ,r4 on r1 rims? if yes could i put ind. tires on the front and get the rear 1s later? k! thank you in advance!
   / L4610 tires? #2
Rims for R-1 tires are usually narrower than the ones for R-4's. You will have to visit the tire websites and look at tire sizes and recommended wheel widths to see if you can match something up. Don't forget the rolling circumference must be the same as the original tires if you have 4wd or you will bind the drive train.
hth
Leroy
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
1985 Ford Ltl9000 Tender Truck (A52128)
1985 Ford Ltl9000...
3 pt Aer-Way (A50514)
2011 Ford F-150 Pickup Truck (A50323)
2011 Ford F-150...
Land Honor Quick Attach Bale Spear (A50515)
Land Honor Quick...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
