L4610 not charging.
   / L4610 not charging. #1
KOsborn
Catlett, Virginia
Case 480 and Case IH 235
I have a l 4610 with a Denso 3 wire alternator that's not charging. I've got 12.89 volts at the battery and 11.5 volts at both wires plugged into the alternator. The wire feeding back to the battery has 11.8 volts at idle and around 13.2 if i rev it. The alternator light is staying on at idle and rev'd. I have a new alternator and an old one and both are giving the same symptoms. Ive cleaned the cables and the frame where the ground mounts. I removed the fuse block and cleaned the ground behind it. Any ideas?
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
1995 FORD LT9000 DUMP TRUCK (A51222)
1995 FORD LT9000...
2022 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2022 JCB HM180T...
