L4610 engine races on cold startup
   / L4610 engine races on cold startup #1
ns_in_tex
Platinum Member
East Texas
Kubota L4610 HSTC, International 2400, Hesston 1280,
It seems my engine races to a much higher rpm on cold startups than when it was new. Cold starup being around 35 degrees, where we live.
It also got to where it might have to turn over several times more when cold, so we started cycling the glow plugs 2 or 3 times when cold so it would fire on the first or second turn. Could that have a bearing on the higher rpm.
It does fall immediately back to normal rpm, but I dislike hearing it run up while cold & no oil pressure.
Is there any adjustment to overcome this?
   / L4610 engine races on cold startup #2
Mine is the same. I also cycle the glow plugs a couple of times when it's cold, and it does initially surge but drops back to idle within a second or two. I have always figured that's just normal.
   / L4610 engine races on cold startup #3
I wouldn't appreciate a start up at 3,000 rpm but I think most have agreed that start up at 1,500 or so is not harmful to a Kubota engine. There has been much discussion on this topic and as I recall, Kubota may even recommend start up at a throttle position higher than idle.
Mine gets started at around 1,500 rpm and the results of Blackstone Lab oil analysis shows no abnormal wear after several years. For what a tractor engine costs, oil analysis every year or two is sure peace of mind for less than a twenty dollar bill.
   / L4610 engine races on cold startup #4
The manual for my model says cold start with 1/2 throttle, that's about 1500rpm. The other thing you could do is use synthetic oil, the primary reason I use it is because of cold starting oil flow.
Thanks everyone. I don't think ours is passing 1/2 throttle. We did look in our manual to see if it said to set to 1/2 throttle, and it does. We have always just started it at idle. On my old International, it says to only turn the fuel on/off lever 1/2 on to start cold, so it would not get too much fuel (which makes it sound like a popping johnny) , so I was under the impression too much fuel was not good for starting.
2002 WACKER RD25 ROLLER (A51222)
2002 WACKER RD25...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A49461)
2018 JLG 1644 4x4...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2014 INTERNATIONAL PROSTAR (A50854)
2014 INTERNATIONAL...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
