L4400 Oil coming up through gear shift
   / L4400 Oil coming up through gear shift #1
probolpher
Lincoln, Vt
Kubota B 2920, John Deere X540, Wheelhorse C-160
Hi folks. Hoping you can answer a question for me. My L4400 has been a great tractor but yesterday oils started leaking up through the bottom of the shifter lever for the transmission. It seems like there might be a relief valve that is clogged for the transmission. Has anyone ever heard of this?
   / L4400 Oil coming up through gear shift #2
Far more likely you have an over fill condition.
Possible water in the transmission if the tractor sits outside. Pressure washing is another way to get water inside.
Check transmission fluid level.
If fluid level high, try partially removing the drain plug(s) after the tractor has been sitting. Just remove enough to see if water comes out as it will sink to the bottom of the transmission and be the first to drain out.
Dave M7040
   / L4400 Oil coming up through gear shift #4
What Dave said.
Additionally, if the oil is coming out of the shifter, the shift boot is torn or missing. Replace it.
   / L4400 Oil coming up through gear shift #5
These are good answers and are the first choice.
I had oil coming out the vent of a HST B26. Oil level was normal to low side of dipstick. The problem was cracks in a rubber elbow on the pump suction side that allowed air to be sucked in and foam the oil. A loose hydraulic filter or housing would give similar results. Could not see the cracks until disassembled and would not spot on the floor when parked except in the vent area. Took me awhile to figure out.
   / L4400 Oil coming up through gear shift #6
Yep. Water lurking at the bottom of transmission cases is pretty common in tractors which live outside. Water is diabolically clever that way.
   / L4400 Oil coming up through gear shift #7
Check the breather tube to see if it is plugged (by a mud daubber etc). I had oil coming out of the gear shifter and opening up the breather tube fixed it.
Case 530 (A50121)
Case 530 (A50121)
2018 INTERNATIONAL MA025 (A52472)
2018 INTERNATIONAL...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
Kubota RTVX1140 (A50121)
Kubota RTVX1140...
