L4330: tips to change hydraulic filter without changing oil?
   / L4330: tips to change hydraulic filter without changing oil? #1
jmc
Elite Member
SW Indiana
Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
Service schedule says change hydraulic filter every 200 hrs but only change hydraulic oil every 400. Counter guy at dealership said that's not a misprint. So last time, I lost a lot of oil in the process, even though I tilted the tractor sideways to elevate the filter side. Anybody have a trick for this to avoid hemorrhaging expensive hydraulic oil while mounting the new filter?
   / L4330: tips to change hydraulic filter without changing oil? #2
Connect your shop vac to the filler port to provide a partial vacuum. You will not prevent all loss, some fluid will be lost with the filter and you will lose a small amount in the line above the filter. This may lose one to two quarts. The thread on the filler cap is one inch female NPT. I threaded a one inch socket to male NPT PVC adapter into it to adapt to my shop vac. Good Luck.
   / L4330: tips to change hydraulic filter without changing oil? #3
Shop vac works well. I had to tape the hose to the fill port due to the design on the 60 series Grand Ls. But it kept oil from coming out with the filters off for several minutes. Oil in the filters came out.
   / L4330: tips to change hydraulic filter without changing oil? #4
wide 5 gal bucket not so tall but wide! take off filter let it fall in the bucket screw new one on make sure you use clean bucket so you can pour it back in the fill hole, just don;t get in a hurry take your time have new filter close or in hand no need to oil the o ring seal it will get plenty on the way end, works for me
   / L4330: tips to change hydraulic filter without changing oil? #5
I've never used the shop vac, I just find all the vents and plug them.
OP here,
Thanks, All, for your great suggestions. Looks like the Clean Bucket option works best for me, especially if I can find all the vents. Aside from the fill port, are there any other vents?
And as since I'll use the Clean Bucket method, is the residual oil in the old filter mostly filtered or mostly unfiltered?
   / L4330: tips to change hydraulic filter without changing oil? #7
The vacuum trick works a treat. Very easy and painless. I did it on my previous L3130 and my current L5240.
2013 GMC Sierra 2500HD Ext. Cab Pickup Truck (A49461)
2013 GMC Sierra...
Blue Concrete Test Shed (A49461)
Blue Concrete Test...
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
Unused 2025 CFG MX20R Mini Excavator (A49461)
Unused 2025 CFG...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A51039)
Rhino FS15...
