Hello,
Haven't seen this problem listed and the Kubota dealer is closed today so.....Went out to start my L4330 but it wouldn't start. The procedure is to turn the key on, depress the clutch and turn the key to start. The Intellipanel displayed "hst" and "neutral". This has happened before so I rocked the speed control pedal fore and aft letting it return to the neutral position and turned the key to start but just got the same message. One time, I had this problem and the Kubota mechanic had me examine the linkage under the floorboard for an obstruction and sure enough there was a small branch caught up in the linkage but not this time. A couple of other times when starting, the hst message was displayed and then there was a chattering relay sound and it started. Anyone know if there is an easy to replace relay that has failed or is there a hard to replace neutral safety switch buried deep inside the transmission?
Thanks for you help
Thanks for you help
