Rockyridge
Bronze Member
I have a question after having the PTO upgraded to remove the ratcheting noise.
Without the ratcheting over ride feature is there an issue with engaging the PTO if you have something like a rotary cutter that has not stopped moving when you are ready to go again? I have been throttling down the engine before putting the PTO out of gear to slow down the rotary cutter before I put it out of gear. That way it stops much sooner than if it was put out of gear at full speed. I知 concerned that putting it in gear again while the out put shaft is still turning fast, driven by the rotary cutter, may be hard on the PTO system because the input shaft will have to be up to the speed of the output shaft immediately.
Do you wait till the implement stops turning or do you just put it in gear and go?
If you do, do hear any noise when engaging it?
Any information will be appreciated
