L4300 DT won't start
   / L4300 DT won't start #1
jfouse
Winchester, VA
Kubota L4300DT
I hadn't used my L4300 DT in a month or two when I went in to start it up recently. When I put in the key and turned it, the dash lights came on for a brief second and then everything went dead as though the battery was dead. But if it was, the lights wouldn't have come on at first, so I'm thinking a fuse somewhere, right? But I checked all (5? 6?) fuses in the fuse panel on the left side and all look intact. Are there others somewhere I'm missing, and/or something else I should check?
   / L4300 DT won't start #2
Sounds like possibly a bad/dead battery ,battery connections. or bad frame ground connection. a lot of times the connection will be good enough for low amperage lights to come on,but as you go to start on the key switch the higher amperage draw will break the poor connection and everything will go dead. Sometimes the lights will come back on sometimes they wont.I would first hook some jumper cables up and see what that does.If that doesn't produce any result then check the battery connections,battery ground connection at the frame. Rule out the obvious first.
Regard's
Sean
C13 MOTOR (A50854)
C13 MOTOR (A50854)
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2014 Doosan DA30 (A51039)
2014 Doosan DA30...
2017 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2004 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
2021 John Deere 9570R Articulated 4WD Tractor (A50657)
2021 John Deere...
