L4240 one-year report
/ L4240 one-year report #1
Johnbro
Western Washington
2010 Kubota L4240
So almost exactly a year ago the L4240HST-3 showed up on a snowy day:
Options included SSQA HD bucket with cutting edge and hooks (installed later), top and tilt with 3 rear remotes, and sunshade. We also bought a Land Pride 72" box scraper with hyd scarifier up and down. Trade in was the 1987 L2250 with about 1050 hours, 42" BB and 3rd party FEL.
We already had some implements from the old tractor and shortly thereafter bought 4000 lb pallet forks for the FEL.
What I overlooked was getting the tires filled and moved to the widest position at the dealer before I took delivery (recently corrected).
Only modifications so far was the installation of Harbor Freight lights with switches (two forward and one rear) on the ROPS and, as noted, filling the rear tires and moving them to the widest position.
Currently the tractor has 155 hours on the meter.
I was a little concerned about this model because I was afraid it would be too big, compared to the L2250 which I thought was a good size for a small (5 acre) property. and, in fact, sometimes the size is a detriment and a smaller tractor would be more useful. However, the power of this machine and the lifting capacity of the LA854 loader more than make up for those infrequent times when I have to maneuver oh so carefully around obstacles.
Big changes from the L2250, aside from sheer power, include the HST and sunshade. The HST is a godsend and I would never be without it again. I find the high-low range selector on the steering column gets a ton of use to quickly change speeds from fast travelling to slow and careful movement and control. The auto throttle advance I find of little practical use, although once it has been reset from the factory it's of some utility. for example, if i have to drive the tractor through some pasture gates I use the ATA so I can stop before the gate, hop off the tractor, open the gate, drive through, hop off and close it, all without having to adjust the hand throttle.
The sunshade is quite useful--in the rainy Pacific NW it's more of a rain shelter than sun shade, but I like that if I remember to tilt the seat forward when I park the tractor it will stay dry until I need to use it again (no more wet butt). Downside of the sunshade is it makes the tractor MUCH bigger--there are a few places I can't get into because of the lack of overhead clearance.
The swivel seat is also a nice addition--I crank it to the right when dragging our road so I can more easily look back at the scraper to see what's going on.
The tractor is noisy (but aren't they all) and the HST whine is annoying but I have gotten used to it by now. I always wear ear muffs when using the tractor so the noise isn't dangerous just tiring.
The other big change-up between this unit and my old tractor is the difference between R1 and R4 tires. My old tractor had R1s and had much better traction in mud than the R4s offer. However, if the bucket was loaded the front tires--even with a lot of air pressure--would almost collapse. The R4s, on the other hand, never flinch no matter how much I carry on the loader.
I found the 4240 to be quite tippy when using the pallet forks with a big load. How much of this was the sheer capacity of the loader and how much was the sub-optimal rear tire setting remains to be seen. Since switching the tire position and filling them I haven't had a chance to test this out.
I think one issue with these bigger tractors is that the FEL capacity grows faster than the weight of the tractor. The L4240 doesn't weigh THAT much more than my old L2250 but has at least twice the lifting capacity of the FEL. I know I have lifted a pallet with 2000 lbs of bagged ice melt on the pallet forks--over the stated capacity but I did it. I never lifted the pallet more than I needed to keep it off the ground and I drove about 1/2 mph over the flattest route I could find to put it down. somewhere I have a picture...
So I always wear my seatbelt and think long and hard about driving with a full load in the bucket or on the forks.
Final conclusion is that this is a terrific tractor and I would highly recommend it to anyone.
Edit: Reading another post brought to mind a couple of points that are pretty important but I've come to take for granted.
First is 3PH implement attachment. My 2250 had the "traditional" 3PH with no TNT. Frankly getting implements on and off was a huge PITA and required WD40 (to loosen perpetually frozen turnbuckles), large box wrench (for leverage to turn turnbuckles), and a sledgehammer to pound the arms on or off the implement. I think my bushhog was on there for about 3 years because it was too much trouble to take it off. The L4240 changed all that with the pin-style lower arms and telescoping connections. Plus the TNT means I can move both the top link and the relative height of one arm just from the hyd controls. It's till no easier to hook up a driveshaft for a PTO implement, but the 3PH arms are quite easy to line up and put on/take off. I would never go back to a turnbuckle style 3PH again.
Second is trivial but well, not so trivial. The 2250 had a sight glass to check the hydraulic fluid. Problem was, I could never tell if the sight glass was over-full or empty, since I never saw a line in the middle of it. This led to a well-intentioned but idiotic neighbor over-filling my transmission case when he borrowed the tractor by several gallons. The fact that the 4240 has an actual dipstick (and an easy one to get to) is a real plus in my mind. As a matter of fact, the overall accessibility of important service items (filters, fillers, zerks, etc) is pretty good on the newer models.
/ L4240 one-year report #2
Nice report. Those big R4's on the L4240 will hold a lot of fluid so I think you will notice a big difference now when you max out the fel.
/ L4240 one-year report #3
Can we have a photo of the added lights?
Wife is pushing 290hrs on her L3940 since last April, it's been great but with the loader on the lights aren't much good, they're mounted to low.
I'll try to get some pics of the light install up in a day or two (weather issues).
/ L4240 one-year report #5
Good to hear. I just upgraded from a l4330 gst to a l4740 Hstc. Still getting used to the hst tranny, but think that once I have some more seat time I will appreciate the ease of operation. In the mean-time I hope I don't rip the high low lever off, I am always grabbing it to shift from forward to reverse. Haha.
/ L4240 one-year report #6
Nice,I like mine;2008 HSTC with 485 hrs.now.I use mine year round;need to put the snow-plow on now first snow today.You are right about the 854 loader ,very powerfull.I popped the rear up with a load of wet dirt and I have loaded R1's and had the box blade on.:thumbsup:
/ L4240 one-year report #7
so glad to hear your tractor is doing a good job for you.
Just posted a write up on the lights as a new thread ("Yet another work lights install...")
/ L4240 one-year report #9
Buying a new tractor gives a person a good feeling deep inside, but when that tractor performs and does everything that is asked of it, it elevates the feeling of satisfaction. I bought a L4400 this past June and it has served me well. Good looking tractor.:thumbsup::tractor:
/ L4240 one-year report #10
So far my 4240 has exceeded my expectations. My only problem has been deciding which attachments I should buy first. I figured that since I had a larger machine I wouldn't use the loader much but I've found I have used it a lot more than expected.
/ L4240 one-year report #11
Johnbro,
How did the R4's do in the snow? I used to have turfs on my old L4330 and they did great unloaded. Now I have the same tires as yours loaded but have not had any snow yet to see if I made the right decision to change up.
Johnbro,
On dry snow they're fine but if it gets soft and smushy it's like mud and clogs up the tread.
/ L4240 one-year report #13
Good news, thanks for the info.
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2016 PETERBILT 579 (A60736)
2016 PETERBILT 579...
2014 LONE STAR TRAILER 18 T/A TRASH TRAILER (A60736)
2014 LONE STAR...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
2019 JCB 457 (A60462)
