L4200 Remote Cable Loader Valve ** HELP **
   / L4200 Remote Cable Loader Valve ** HELP ** #1
mcd176
Wheeling, WV
Kubota M6800HD / Kubota B2150
I am starting to install my remote cable FEL valve to my L4200 and have a few questions.
1. My old loader mounted valve has 3 lines going to the hydraulic block on the right of the tractor, I am assuming IN, OUT and TANK, but the directions in the install manual for an LA 680 loader only shows 2 hoses being hooked up to the block?????
2. if anyone has a remote cable valve on an L3600 or L4200 can you PLEASE post some pics of the install??
My tractor has rear remote as well
THANK YOU
   / L4200 Remote Cable Loader Valve ** HELP ** #2
The three lines are IN, OUT(to tank) and PB(power beyond), That's all I can help you with unfortunately...
Thanks KennyD, I got it all installed today, Boy whata difference the fender mounted joystick makes vs. the loader mounted stick.
-Mike
   / L4200 Remote Cable Loader Valve ** HELP ** #4
-Mike
Your welcome. The loader mounted joystick and the split brakes on the same side of the HST pedal was a major factor that steered me away from Kubota years ago.
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52128)
2017 Rogator...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52128)
Adams Load Out...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
