l4200 hydrolic isue
   / l4200 hydrolic isue #1
fastback88
Bronze Member
Sturgeon Bay WI
Kubota L4200gtsc,LA680 loader
I have kubota l4200GTSC with around 600 hrs. Today when I was use my 3 point cultivator 6' the 3 point worked fine for an hr or so then it started not to raise as fast as it normaly does then it would not raise at all so I played with the loader and the loader would raise ,dump and role fine but would not lower unless I put it in float played with the joy stick a little then every thing worked fine for a while then it did it again played with the joy stick again then evey thing worked fine whats going on?
Thanks Jeremy
I did some more testing today and found out the if I have the three point lever in the raised position and it will not go up ,it will when I raise the loader.
It seams to me like ther is a stuck valve somewere.Any help will be apprecaited
   / l4200 hydrolic isue #3
I am no expert but it sounds like a loader valve problem. A broken spring or stuck spool so you don't get any Power Beyond pressure to the 3ph.
Put this in the Hydraulics Section. There are a lot of knowledgeable people there who can help you.
If you have the loader hydraulic block under the right foot rest, like on my L3010, you could disconnect the pressure hoses to the loader and plug the ports then turn the block valve to the 'no loader' position and check your 3ph operation. See your tractor and loader manuals for loader hydraulics hookup to understand this block and valve.
   / l4200 hydrolic isue #4
Hello Jeremy...
The problem will be in the loader control... to confirm this, look on the right side of your tractor ...
just in front of the hydraulic filter there are 2 hoses... between those 2 hoses is a large slotted screw head... that is the selector for your hydraulic flow... Vertical is with a loader, Horizontal is for No Loader.
You can only turn it 90 degrees... turn it to the Horizontal position and check your 3point...
Put it back in the Vertical position and the hydraulic system runs first to the loader and then to the rear of the tractor...
If the 3pt still will not function, check your Loader Control linkage ... if the linkage is okay and centered... then as Gordon Gould said your problem will be inside the Control Valve... Post back with what you find.. KennyV
:thumbsup:Thanks guys I will check some time tommorow, my tractors at the job site.
Killbros 250 bu Gravity Wagon (A50515)
Killbros 250 bu...
2025 LandHonor LDH-FPR36 36in Round Metal Fire Pit Ring (A49462)
2025 LandHonor...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
2007 WABASH 53FT DRY VAN TRAILER (A51222)
2007 WABASH 53FT...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
