npaden
Platinum Member
Okay, I've been tinkering with my new to me 1996 L4200 GST and have a few questions.
Kenny mentioned that there should be 2 springs in the forward and reverse lever but I can't figure it out.
The parts diagram only shows one: (Part 60)
(These pictures are very small - 13kb so I went ahead and posted them in the thread instead of linking them)
Something seems to be missing on mine that makes it harder to shift back and forth and for sure I have to push the lever down to get the electronic neutral indicator to allow the tractor to start.
I pulled the tilt steering shaft screw out but I couldn't get the broken off handle unscrewed. I may have to take it to someone to get it drilled out and retapped. The part only cost $19 so maybe I'll just buy a new one.
Something seems messed up with the seat also. It doesn't seem to be very stable. Is there something keeps the rear part of the seat more stable?
Last questions are electrical. For some reason after I had the tilt steering wheel moving the tractor won't turn off from the ignition switch anymore. I turn the key off and pull the key out and the tractor keeps running. I have to pull the kill switch to shut it off. It was working correctly earlier today so I'm not sure if I messed something up or if it just happened to break somehow?
The hazard lights don't work also (they never have) is there an easy way to troubleshoot them?
I got a little better with the shifting, but it still jumps into gear pretty hard with a little clanking on the higher gears. Everything is quiet and smooth in gears 1-4 but from 5 on up it jumps in pretty hard.
I put in another hour or so of seat time and everything seems to be working well. Just want to get the kinks worked out.
Thanks in advance for any input!
Nathan
Nathan
