nightowl490
Bronze Member
Here goes nothing! Riding down the road (enjoying the warm IL March) 2WD in high gear, 1/3rd Throttle, on my way to by buddy's shop for some minor FEL loader welding. I look down to the right front bevel area and see 90W pouring out into the inner rim. I pull off, lift front of tractor up with FEL and take a look. There is a hole, little bit bigger than a pinhole in the lower CAP of the bevel gear houseing. Only being about 1/4 mile from my shop I creep back at idle and park in shop. Pull wheel and look again. There was a peice of metal protruding out of the cap at the hole and the cap itself was dented out with dimples :ashamed: uh oh. I take pliers and remove metal peice and more oil. After looking it over I pull off the cap, inside of cap is serious metal shavings and all my needle bearings. I assume needle bearing came from the one listed in my parts manual. I go ahead and remove the hub (knowing it will need flushed) to expose the planetary to see more shaveings. Grabbing the bottom bevel gear there is considerable play/slop and the bevel houseing itself is slightly (wollered) where it slapped the housing for how knows how long
. Pull off the top of the bevel and reveals plenty of grease and no slap at top of bevel shaft, thank goodness.
So here I sit with multiple copies and zoomed copies of the bevel gear shaft, front axle and front axle case in front of me and a pen and paper with part numbers. I plan on documenting this event with many pics and many reviews as well as findings.
It should be noted there were no symptoms/signs I felt or saw (oil leak) to pre-empt this event. ANY THOUGHTS SO FAR?
