L4150 air in fuel lines
   / L4150 air in fuel lines #1
boscojud
peoria il
kubota
I have an older L4150 (1987-1988) It stop running for no apparent reason (full tank of fuel,fuel filter OK & no water in separator) I replaced filter and after the usual hours and hours of trying to bled any air out I replaced the fuel transfer pump. This made a big difference but now I can't seem to get the air out of the fourth injector line (counting from front to back) If I leave the line loose allowing the air to escape the engine will run. If I close the line the engine will slowly die. Please Help !!!!
   / L4150 air in fuel lines #2
It sounds like there is a partial restriction inside the tank outlet (debris collected down in the outlet bowl on the bottom of the tank). Your new transfer pump can pull harder - so it is delivering some fuel. But it could also be pulling in some air somewhere - maybe around the selector valve on the filter housing. Any air in the injector lines will cushion the fuel pressure pulses and the injectors won't spray fuel like they should.
First, try carefully blowing some compressed air back into the tank through the fuel tube that leads to the filter. That will temporarily push away any collected skudge and the tractor should run better - may need to bleed the injector pipes again. If this helps, the tank needs cleaning out. It takes some doing - sometimes the last few crumbs need a vacuum cleaner. I had to take my tank off and dump it out - there's a baffle partially covering the outlet so its not very accessible thru the filler neck.
BTW, if the tank outlet is unrestricted these tractors will run ok without a transfer pump - just need a full tank.
Hope this is useful. As always, prompt cheerful refund if advice turns out to be bogus. Dick B
14ft Bi-Parting Iron Gate (Cow Design) (A51573)
14ft Bi-Parting...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
LEEBOY PF1510B ASPHAULT PAVER (A51406)
LEEBOY PF1510B...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
