Backhoe L3940 HST 550hr. Random lockup of joystick positions, outriggers, reverse, FEL, etc
   / L3940 HST 550hr. Random lockup of joystick positions, outriggers, reverse, FEL, etc #1
JerryBuilt
Woolwine, VA
Kubota L3940, KX123-3 Mini EX, MF35 Deluxe, F350 dump w/ johnny lift, Can Am 1000
Hello, my first post! Thanks to all who have posted and helped me solve my previous problems!
L3940, HST BH, FEL, 3rd valve for grapple (installed by dealer)
During operation, I am experiencing random inoperative hydraulic functions. IE, the BH wont swing back to center, one outrigger wont retract, once I could not press the reverse pedal, and once I had very little engine power to make it back to the barn. It is like the levers are frozen in place. Then everything works fine. It started as a rare occurrence, but is happening regularly It IS due for it's 500 hr maintenance. I am seeing a tiny bit of fluid leakage under the BH joystick station, to the operator floor. I removed the cover, but found nothing unusual. Any suggestions?
   / L3940 HST 550hr. Random lockup of joystick positions, outriggers, reverse, FEL, etc #2
I'm surprised no one attempted to provide an opinion. I would think you've solved the problem by now, but if not - did you check your HST fluid level?
It got worst, as the hoe would not come back to center or would just pivot hard right, dipstick would slow down, and one outrigger would take 2 minutes to retract. A couple of times an outrigger just extended while I was using the front mounted grapple clearing brush and limbs. Too unsafe to continue on my mountain property. I took the tractor in for service at a local (mostly Massey) tractor repair shop. Several of the O rings and the wipers had failed in the backhoe valve assembly, allowing pressure to build up and activate or block the fluid passages. 7 valves X 2 = 14. The O rings were only a couple bucks, but the wipers ( like a seat that housed the o rings) were a whopping $25 to $27 (25 x 14 =$350) each! I elected to have all replaced for fear the rest were right behind. So after new UDT2 fluid, filters, parts, and a few hundred in labor, for a total of $1400, the tractor and backhoe are running great! Just not happy about the over priced orange fluid ($406) and parts ($450).
   / L3940 HST 550hr. Random lockup of joystick positions, outriggers, reverse, FEL, etc #4
Wow - that's quite a bit. How old is your tractor? I'm curious how long those O-rings had been in there. I'm glad to hear you have it all taken care of, albeit much lighter in the wallet though. :shocked:
Thanks, It is a 2011!, I wasn't expecting anything this major so soon. I bought it Dec. 2013 with 450 hr. It was a trade in at a Kubota dealer and had 7 months warranty on the tractor, not the implements.
I suspect the owner never changed the fluids? (and I had not either) as he was trading it in on a new tractor. $400 every 200 hours for just the HST fluids, not including the filters is a little steep. I got a decent deal on it and it is a great tractor for this bigger (52 acre) property, with all the clearing and stump removal needed. It does everything I ask of it...... except that one big stump.
   / L3940 HST 550hr. Random lockup of joystick positions, outriggers, reverse, FEL, etc #6
Well it sounds like you don't use if for commercial use, so it will probably take a year or two to get 200 more hours on it. It's still hard to believe you had O-rings going bad due to the fluid having (what is suspected to have) 450 hours on it.
I bet you are more stubborn then at big stump and it will eventually give way to the mighty Kubota!
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
BETTER BUILT FUEL CELL (A58214)
BETTER BUILT FUEL...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
Eagle Weathervane (A55853)
Eagle Weathervane...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
