WazzuInOregon
- Joined
- May 11, 2021
- Messages
- 1
- Tractor
- Kubota L3901
I was doing some brush cutting this past week and after about 30 minutes my tractor powered down and died. When I would try to restart it, it would turn over very slowly. After letting it sit for about an hour or so, it would start back up. I could cut for another 30 mins and then it would power down and stop again. I switched implements to a tiller. Same thing happened. I switched because I needed to till, not that I thought it would get a different results.
So, at first I thought of the usual suspects for stalling/power loss: fuel or air. I tried running without the fuel cap. Same thing. The tractor was due for it's 200 hour service, so I got all the filters, replaced everything (fuel filter, cleaned out float and replaced filter there). After getting things back together and topped off, I started it back up and then went and did some work with it for about an hour and a half. I moved some dirt from a mudslide on a little access road, used the bucked to grade it a bit, and scooped and moved some other dirt and mud from here to there. Basically, giving it a work out, but not with an implement, just the front loader. Everything was fine.
I hooked the brush cutter back up, went back to one of my fields and started mowing...30 minutes later...power down and died. I was do irritated.
Any ideas or thoughts as to what might be going on? Why is this only happened when I'm using a PTO implement?
