L39 TLB won't start
   / L39 TLB won't start #1
blackpowder
2006 L-39 999 hrs. Won't fire up. Turns over fine just won't catch fire. Any ideas. Fuel good, filter clean, ran OK 4 weeks ago.
   / L39 TLB won't start #2
Did you check for nest in air cleaner?
Did you crack the fuel lines at each injector to make sure there is fuel there?
Fuel supply is OK. I can't hear the solenoid when I turn the key.
   / L39 TLB won't start #4
Does the glow plug light come on?
Have you checked for blown fuses?
There is an engine stop (fuel cut off) solenoid and relay that controls the solenoid. The solenoid is on the front of the injector pump. You could check that you have power on the solenoid when the ignition is on.
It was the seat switch. I removed it and broke it into ten thousand pieces. Spliced the leads and fired her up. All good.
   / L39 TLB won't start #6
I bet that made you happy, gotta love simple fixes
   / L39 TLB won't start #7
So the seat switch only controls the solenoid and not the starter circuit? Seems like strange logic, what's the point of allowing you to drain the battery trying to start an engine with no fuel delivery?
TRUBILT SKID STEER QUICK ATTACH PALLET FORKS (A51244)
TRUBILT SKID STEER...
2015 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51243)
2015 FORD F750 XL...
Genie GTH-644 (A50490)
2014 Ford F-150 Pickup Truck (A50323)
2014 Ford F-150...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
