L3830 Starting/Running Issue
   / L3830 Starting/Running Issue #1
clvickers
Nassau County Fla
Kubota L3830
I've had some issues in the past with my L3830 where I would get up on her and try to start her. When I turned the Key the engine would turn over but wouldn't stay running <I was hearing a click when I turn the key and another click when it shut down as soon as I let go of the key>. The throttle was pulled all the way back slow when this would happen. If I increased the throttle, then hit the key, the engine start up and run.
Jump forward to tonight. Started tractor and picked up a bale of hay and started backing out of the shed. Heard a click and tractor shut down. Restarted fine, moving again, and Click again... Shut down. It did it one more time before I got it back into the shed.
anyone else see this before???
I'm wondering if this is the OPC Relay switch that "awhite" was having back in 09.. :confused:
   / L3830 Starting/Running Issue #2
To make a difference in the throttle position as to if it would run or not I think the fuel shut off is not activating properly. I'd check the wiring and see if anything is loose first and clean the connections if needed.
377972 (A48837)
377972 (A48837)
2014 Dodge Charger Sedan (A46684)
2014 Dodge Charger...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A50046)
2017 MACK CHU613...
2014 Ford F-250 Pickup Truck, VIN # 1FT7W2B66EEA79923 (A48836)
2014 Ford F-250...
2010 Cadillac SRX Luxury SUV (A48082)
2010 Cadillac SRX...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A48836)
2013 International...
