L3830 Fuel leak from fitting going into filter housing.
   / L3830 Fuel leak from fitting going into filter housing. #1
sanmigmike
Bronze Member
S.E. of Portland OR
Kubota L3830 HST
Recently I noticed fuel dripping and then running from a 鏑 shaped fitting from the rear, engine side of the fuel filter housing. Called the dealer and the mechanic said to tap it back in. Did that and the leak seemed to stop. He implied that it was not all all an unusual problem. So I still have a few questions:
Is it a common problem?
The fitting is L shaped and the part that goes into the fuel filter housing top is tapered with a groove in it and in the corresponding hole in the filter housing there is a tapered hole with what looks like a ring. So what the heck are these style of fittings called?
I have never had to use the on-on-off valve on top of the fuel filter housing before so what are the two 登n positions for? I might have a clue on what the 登ff does? Is one to help purge air in the system? When I started it there was a slight surging and I increased the RPM and changed to the other 登n no idea if either did anything but it smoothed out.
Thanks,
Michael
   / L3830 Fuel leak from fitting going into filter housing. #2
U can pinch off the rubber lines so air doesn't get in the system & remove the housing.. DEGREASE IT & the fitting, & epoxy it into the housing..
Problem solved.
2013 VOLVO VNM DAY CAB (A51222)
2013 VOLVO VNM DAY...
2010 CATERPILLAR MINI EXCAVATOR 303C (A50854)
2010 CATERPILLAR...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2016 KENWORTH T660 SLEEPER (A50854)
2016 KENWORTH T660...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
