L3800HST Losing Hydraulic Fluid
   / L3800HST Losing Hydraulic Fluid #1
RobD70
Marathon, WI
2013 Kubota L3800 HST
I have a L3800HST with about 165-170 hrs on it. I recently had a 3rd function valve installed. When I took it to the dealer to install that 3rd function valve, I was told it was low on fluid, so they put almost a gallon in it. I had to take the tractor back because they installed the valve wrong, and when I picked it back up, I was again told it was low on hydraulic fluid. I just thought, it couldnt be, I looked at the site glass maybe a week before and it was good. I cant find where it is leaking out. I do run it in 4wd most of the time as I do alot of power raking or some brush hogging to. The first time they added fluid, they over filled it some as it blew fluid out a breather hose under the left side of the seat. Over the weekend I spread 40 yards of top soil and power raked it out. It appears to be low yet again. No puddles on my trailer and none on the garage floor. I looked over all the hoses and connections and no fluid or wet spots. I crawled under the tractor and oticed some fluid on the bottom of the block that the drive shaft that runs to the front axle comes out of, but not alotand it could be old fluid from when it was over filled and ran down the side. I wiped it all dry and will check once I re-fill it. Also, right next to the dipstick for engine oil, there is some sort of pump or something that looked like it had a little fluid on it, but it again wasnt much and could of been from the recent hydraulic work. I really dont know where the fluid is going. I will have to refill it and run it and check right away. Is it possible it leaks a bit til it gets to a certain level, then dont come out anymore? Any ideas what to check?
   / L3800HST Losing Hydraulic Fluid #2
If you can't find a leak and are adding fluid it's got to be going somewhere check eng oil and make sure its not overfull pump seal could be leaking in to crankcase? you don't think dealer lost oil when installing valve I would keep a close check on it.
The dealer is who added the fluid both times up there. I checked the oil and its good. I will fill it up, run it some and see if I can find the leak that way. Just odd...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
7021 (A50322)
7021 (A50322)
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
JLG 1932R 19FT Scissor Lift (A50322)
JLG 1932R 19FT...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
