Dirt Moving L3800
   / L3800 #1
Crw
Farmall 140
I just purchased a l3800 hst and I have a hill at my house that needs to be regraded it will require large amounts of dirt to be moved I was wondering if this is bad for my tractor or loader to dig with it
   / L3800 #2
As long as you remember that it is a loader and not a bulldozer you will be fine. take it slow and easy. A boxblade will likely be better for scraping out and moving the dirt to a pile and then using the loader to pick it up and carry or load it in a transport.
   / L3800 #3
Ditto that. I dug a duck pond with mine. I used a middle buster about every two feet to loosen up the dirt. Then just scooped it up with the loader. I have some pretty hard clay down around 18 inches. No match for the middle buster. It went much faster than I originally expected. Grinding away at that clay with the FEL just seemed to be really hard on all the parts.
I also have a 3800.
   / L3800 #4
If you're doing much digging a tooth bar on the bucket will make the job much easier. If the ground is hard a subsoiler or middle buster will be worth using.
I put in a driveway last year 120 ft long and 30 ft wide. This required removing all the top soil (and rocks) to a depth of about 10" and then putting in a base of ballast stone with crush & run on top. All done with an L3800.
Mac
2020 EZGO GOLF CART (A50324)
2020 EZGO GOLF...
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
2025 LandHonor PR-12-72W Hydraulic 72in Power Rake Skid Steer Attachment (A49462)
2025 LandHonor...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
Mesh Office Chair (A49462)
Mesh Office Chair...
2014 Doosan DA30 (A52128)
2014 Doosan DA30...
