L3800 PTO
   / L3800 PTO #1
F2036
My L3800 HST arrived yesterday. On the Kubota website it says that it has a live pto, but in the manual it says you must use the clutch when putting the pto in gear or takeing it out of gear.
To me a live pto does not need a clutch to be put into gear. What am I missing?
   / L3800 PTO #2
I'm no tractor expert, but every PTO I have seen so far has some sort of clutch for engaging & disengaging.
   / L3800 PTO #3
Don't know much about the 2800, but manual for the Grand L series says nothing about using the clutch to engage or disengage the PTO.
   / L3800 PTO #4
Ok I will tell you what I think it means, Yes you have a live PTO, but yes you will need to use the clutch to safely engage or disengage the pto, but you do not have to be moving the tractor. Now that said with a hydo you dont have to do anything with the clutch anyway to move the tractor, so it is kinda redundant. But if your tractor was a gear model, you still would not have to move the tractor, to engage the PTO, as the PTO would engage first as the clutch starts to engage ,then the tractor will start to move as you continue letting out the clutch. You do not have a hydraulic/electric actuated PTO, where you press a button and don't have to use the clutch at all. In the old days on some older tractors that did not have "live" power you had to move the tractor and the pto at the same time. in using a baler or something like that with live power you can get the baler up to speed first before you start shoving hay into it, by driving foward..
Anyway this is my understanding of the term. Perhaps other would care to comment.
James K0UA
   / L3800 PTO #6
+1
You do indeed have a live PTO. Which DOES require the use of a clutch to engage. It uses a 2-stage clutch . You use the main pedal, but instead of pushing it half way to make gear changes, you have to push it all the way for PTO use.
Even an independent uses a clutch. But it is a seperate clutch all together. It can either be mechanical or hydraulic. Hydraulics are usually the push button types. That is where most get the impression that a clutch is not used. When in reality, a clutch IS being used, just not by your foot.
This TractorData.com - Power Take-Off Is the best and simplest explination I have came across to describe the different PTO's.
   / L3800 PTO #7
+1
The Tractor Data is a good one, but it could be a little confusing when dealing with HST and especially the L Series. It appears the Lxx00 Series requires use of the clutch to engage/disengage the PTO while the Grand L doesn't even though depressing the clutch disengages the power to the PTO.
We have had tractors with all types and it sure can be confusing for a new owner.
   / L3800 PTO #8
Doesn't the Grand L have the Hydraulic clutch pack,? so that is why you dont need to use the main clutch? and the L series does not. Maybe someone could clarify here.
James K0UA
   / L3800 PTO #9
You probably have a 2-stage clutch. Depress it 1/2 way down and you can shift gears (and the PTO keeps turning). Push it all the way down to engage or disengage the PTO.
I think you're confusing "Live" with "Independent" PTO's.
   / L3800 PTO #10
I do not think you have a 2-stage clutch as it is not needed with a hydro, Just a single plate clutch. As Roy said you have live pto not independent.
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
2002 Ford Ranger Ext. Cab Pickup Truck (A50323)
2002 Ford Ranger...
2012 UTILITY VS2DX 53FT DRY VAN TRAILER (A52141)
2012 UTILITY VS2DX...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2007 BMW 750 Sedan (A50324)
2007 BMW 750 Sedan...
1995 Well-Craft 210 SS Elcipse Boat (A50515)
1995 Well-Craft...
