L3710 loader hydraulic leak
   / L3710 loader hydraulic leak #1
Anonymous Poster
Epic Contributor
Anyone have problems with the retaining bracket on the side arm of the loader wearing through the hydraulic pipes to the bucket? The first time it happened the tractor had 100 hours on it and two lines were rubbed through. Now with 300 hours on it another line has a pin hole. Seems like a poor design on the hold down bracket (metal to metal viberating).
   / L3710 loader hydraulic leak #2
I've only got 75 hours on my 3710 but I'll sure check and see if the hyd. lines are rubbing in the morning.
Thanks for the heads-up.
   / L3710 loader hydraulic leak #3
No leak at three hundred hours.
   / L3710 loader hydraulic leak #4
Usually they have a small strip of rubber under the hold down bracket to eliminate the metal to metal contact. If you don't have it I would add it.
Yea, you would have thought there would have be rubber between all the brackets, but even when they replaced two of them the first time under warranty, the dealer didn't put anything between the steel pipes and the hold down brackets. When I questioned them on it this time they said they never heard of this problem. I first thought the bolts weren't torqued properly when it was originally assembled, however they assured me that wasn't the problem. And again it happened!
   / L3710 loader hydraulic leak #6
700 hours no leaks or wear. The brackets do have the rubber inserts.
Is that a 3710? What year?
Dealer came out, replaced line and put rubber between steel line and holding bracket on FEL. They covered it under warranty. /forums/images/graemlins/smile.gif
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
1267 (A50490)
1267 (A50490)
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
2013 HINO 388 (A50854)
