Airdriver
The valve above the clear fuel filter bowl has 3 positions, two on and one off. Fuel flows from none of them. Overnight, enough fuel will seep into the bowl to refill it. You can watch the fuel level in the bowl go down while the tractor runs a few seconds and then stops.
Fuel gage read about 1/2 when this first happened. I added 2 more gallons (7.7gal tank) to be sure. Fuel is visible looking in the filler neck.
Are there any tricks about this tank? I removed the large rubber fuel line on top of the filter bowl housing and blew air through it back through the tank. Air exited the fuel filler neck, as you would think. But if there was an obstruction, it was not dislodged, even temporarily, for there was still no fuel flow from the fuel line.
Any ideas?
Any ideas?
