Microfarms, I've got a Kubota with about 8000 hours on it. So after a few thousand hours I could buy into the seals I've had to replace mine. The hydraulic hookup may just be a loose connection. It can happen at any time. The clutch on mine I had to replace at about 5000-6000 hours. But if you have a shuttle shift and are mowing at pto speed in high range it really abuses a clutch when going from forward to reverse. The front axle pivot point I've never heard any problems with that. Another thing that comes to mind is if your up north and the tractor was used pushing snow. Always in fourwheel drive even on hard surfaces.
What more than likely stemmed alot of the problems was leaks, then the axle was run out of fluid and took out the ring and pinion. Bearings might have seized from lack of lubracation. Spun the bearing, ruining the axle tube.
Your tractor is about 5 years old, so about 220 hours a year was put on the tractor. Thats about 6 weeks a year at 40 hours a week running at pto speed.
Your tractor was more than likely used commerically and depreciated over five years then traded on a new one.
Lemon---unlikey
Used hard and put away wet--likely
Thats the sad thing about alot of landscape companies. They have people running the equipment who just don't care. Needless to say what kind of up keep was done to the machine. So either you have the problems worked out of it or you'll have a bunch more coming. It the latter is the case, trade it in or sell it and get another.
Did you buy this tractor from a dealer?
Try to find out it's past history if possible.
Sorry to hear about your bad luck
Gordon
