L3600 Engine won't shut off
   / L3600 Engine won't shut off #1
VAWoods
Bluemont, VA
Kubota L3600
L3600 Engine won\'t shut off
I have a '97 Kubota L3600 that will not shut off when I turn the key to the off position.
The kill knob can be pulled out right next to the key which shuts off the air to the engine, taht works just fine.
Any idea where I can start to trouble shoot the problem? I'm inclined to believe that there is some sort of celenoid that is activated by the key to shut off the air. Maybe I should start there?
   / L3600 Engine won't shut off #3
Re: L3600 Engine won\'t shut off
It's probably a fuse. Either one is blown or the connection is dirty. I had this happen to me on my L4200 and I just cleaned the fuses and it fixed it.
   / L3600 Engine won't shut off #4
   / L3600 Engine won't shut off #5
npaden is probably right, check the fuse… By the way the kill knob or the solenoid do not choke off the air… they shut off the fuel at the injector pump. KennyV.
   / L3600 Engine won't shut off #6
   / L3600 Engine won't shut off #7
I agree, use a voltmeter to check the voltage across the fuel cut-off solenoid on the injection pump, in both the key "on" & "off" positions (without the engine running). That will tell you if it's getting proper switched power. If that looks good, you can check the solenoid itself by (carefully) jumpering from the battery + terminal to the solenoid's post - listen for it to click on & off as you touch the jumper to the post. If it's stuck open, it won't do anything.
   / L3600 Engine won't shut off #8
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A49461)
2021 Interstate...
2016 LINK-BELT  235X3 SPIN ACE EXCAVATOR (A50854)
2016 LINK-BELT...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
7046 (A50322)
7046 (A50322)
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
