L3560 Price check
   / L3560 Price check #1
KGB1
Missouri
Ford. 2110
I'm in the market for a new 3560(non cab) with 805 loader and r4's. I'm being quoted 24k what are you guys seeing?
thank you
   / L3560 Price check #2
thank you
I paid a tad over 24K out the door
L3560 non-cab, HST, LA805 loader with R4's. Also had a QA bale spear thrown in.
I love this tractor!
   / L3560 Price check #3
In February 2013 I paid $27,500 for open station L3560/HST with following options: LA805 FEL, L2296 SSQA H-D, RB Bucket, Draft Control, R4/industrial tires, dealer install of Stebl horn, which I provided.
No sales tax on ag equipment in Florida.
Minimal freight from Kubota's Georgia plants to North Florida, where I live.
Great tractor. No regrets spending $27,500.
   / L3560 Price check
Do you remember the setting on the width of the rear wheels? There are 4 settings
   / L3560 Price check #5
My tread width with R4s is 52.2" Outside-to-outside is 70" My inside-to-inside distance is 34".
Measured tonight for first time. As it is flat where I live in Florida, I presume my dealer sets them narrow unless instructed otherwise.
Grand L Operator's Manual specs four tread widths for L3560 with R1s, three withs with R4s: TREAD is center-to-center.
Farm: 47.2", 51.2", 54.5", 58.3"
IND:~~~~~~52.2", 53.5", 57.7"
R1 rims must be fairly different from R4 rims.
   / L3560 Price check
Is 52.4 the measurement to the center of the rim? I'm trying to determine the overall width if I go with a larger setting. Would I add 18 inches roughly to let's say 57.7? I have R4's
   / L3560 Price check #7
Center-of-tire, Center-of-rim, same 52.2"
I cannot answer your question but minor increases in tire spread make big increases in stability.
Wheels spacers @ $300 a pair, commonly add only 1-1/2" to 2" per side.
Changing to bulbous Michelin radial tractor tires would increase your overall tractor width.
Or consider one of the larger Grand L's, which are about 6" wider than an L3560.
What are you trying to accomplish?
   / L3560 Price check #8
KGB1,
Tread measurements are to the rim centerline. 17.5L-24 Industrial tires have a section width of 17.1" simply add this to the tread width's given above to obtain the overall width. (17.1" is from the Titan Catalog)
   / L3560 Price check
KGB1,
That makes sense. I'll probably get them set to the widest setting. Thank you
10' WROUGHT IRON SITE FENCE (A51248)
10' WROUGHT IRON...
2018 CATERPILLAR 299D2 SKID STEER (A51246)
2018 CATERPILLAR...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
2000 Ford F-150 Pickup Truck, VIN # 1FTRX17W7YNA75070 (A51572)
2000 Ford F-150...
