L35 Rear Hydraulics?
   / L35 Rear Hydraulics? #1
Anonymous Poster
Epic Contributor
Does anybody know if Kubota, or other company, offers a "neat" setup for rear (remote) hydraulics for the L35 Tractor/Loader/Backhoe? I would like to use "top-n-tilt" hydraulic cylinders on a box scraper (with hydraulic activated ripper teeth). The setup all the dealers offer mounts on top of the right fender (or bar). It includes the valve bodies with handles on top...oil leaks and hoses everywhere!! Every one that I've seen is a mess. Looks like a poor aftermarket solution. I'm considering electro-hydraulics (www.vandminc.com) but I'm afraid I won't get the "feathering" needed.
Please Advise...thanks.
Dave
   / L35 Rear Hydraulics? #2
Dave,
If you find a good set up, let us know. I have looked for a kit type system for the B21 with out any luck. Guess I need to talk Bird or one of the other hydraulically knowledgeable types to vacation in my area./w3tcompact/icons/smile.gif
I did notice that TractorSmart offers remotes as an option on the L48, so there may be hope.
MarkV
   / L35 Rear Hydraulics? #3
My neighbor has an L35TLB, and I'm pretty sure he's got T&T too. At least, I "think" I saw a top cylinder on it when I was talking to him the other day. /w3tcompact/icons/smile.gif Don't know if it's the "neat" variety you're talking about./w3tcompact/icons/crazy.gif I suspect not. Will try to get by there and find out for you./w3tcompact/icons/smile.gif
The GlueGuy
I think I found an acceptable solution. Gearmore makes a (New) Valve Bracket for both Kubota B & L series tractors for T&T setup. The bracket consists of: rollbar clamp, tubular arm with valve mounting plate, safety valve cover with instructional decal, all hardware powder coated black.
Model VB-170-3K for B series (weight 30 lbs)
Model VB-301-3K for L series (weight 30 lbs)
Or you can get the entire kit (cylinders, valve bracket, quick coupler bracket, valves, hoses, etc.) from Gearmore. (909)548-4848
Good Luck,
-dpm
Wilrich Field Cultivator (A50515)
Wilrich Field...
2014 International Durastar 4300 Terex BT3063 63ft 15 Ton Crane Truck (A50323)
2014 International...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A52141)
2004 HYUNDAI...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
Land Honor Tree Puller (A50515)
Land Honor Tree...
2018 Bobcat T870 Skidloader (RIDE AND DRIVE) (A50774)
2018 Bobcat T870...
