L35 electrical issues
   / L35 electrical issues #1
TURKEY131
NJ
Kubota L35, RTV500, L5030, Kioti DK55c
I am having an ongoing to issues with my machine. Currently my glow plug light does not illuminate when the ignition is turned on. I have replaced the glow plug relay with that did not fixing the problem. When I turn the key off the shut off solenoid does not work. I have changed the solenoid and checked the fuses with that not resolving the issues. Finally my warning flasher lights are not working. The headlights work and the work lights as well. I have checked the fuses and they are fine. I replaced the lights and cleaned up the metal where they come into contact with the metal so I have a good contact. Any help would be appreciated.
   / L35 electrical issues #2
The glow plug problem is most likely the glow plug controller - they do tend to die. Mine did a few years back and I bypassed mine with a big button on the dash - I like the button better. My fuel shut-off solenoid doesn't work either - I've been pulling the manual shut off since I got my L4200 in 2006 (no help, I know). I'd check the dashboard switch for your flasher problem - perhaps a broken wire at the switch or a broken contact inside. Check the I/O with a voltmeter.
   / L35 electrical issues #3
Your fuel shut-off solenoid issue could be at the fuse box, thats where my problem was,
the fuse was good, But' the contacts themselves for the fuse were corroded,
sometimes even the fuse itself "looKs" good but the ends are corroded, light sandpaper
the ends, check all your fuses for corrosion, could be where many of your issues lye.
On the L4200, I believe it's at the bottom right, or could be bottom left.
2022 Heli Forklift (A51573)
2022 Heli Forklift...
2022 CATERPILLAR 301.7CR EXCAVATOR (A51246)
2022 CATERPILLAR...
UNUSED FUTURE VR66 66" VIBRATORY ROLLER (A51248)
UNUSED FUTURE VR66...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
