Backhoe L35 Backhoe Removal
   / L35 Backhoe Removal #1
Keuka
Bronze Member
I bought a used L35 and I got a manual for the tractor but there isn't any information on connecting and disconnecting the (BT900) backhoe attachment. I see there is a seperate operation manual available for the BT900 backhoe but from the price, Kubota is sure proud of their manuals. Can anyone tell me if the backhoe manual has mounting instructions for an L35 Tractor?
It doesn't look like taking off the backhoe is a big deal if you know what your doing. It does look like you could get into a whole lot of trouble if you go at it like "let me try boss".
   / L35 Backhoe Removal #2
They are easy! you should only need a owners manual which isn't to much compared to the service manuals!
To watch any of the Kubota's or to get a manual for any of the frame mounted backhoe's should be good enough to get you through the mounting and dismounting. They are nearly the same for procedures right down to the BX series!
71050 (A49346)
71050 (A49346)
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2024 Iron Bull 20ft T/A Equipment Trailer (A49461)
2024 Iron Bull...
TEST BID LOT (A50774)
