L345DT Transmission Question
   / L345DT Transmission Question #1
NJDonzi
Farmingdale, NJ
Kubota L345DT
I have not yet found an owners service manual yet and had a few questions on the transmission in my machine.
1. How full should the trans be? I assume there is a side plug you can remove and fill until it seeps.
2. What type of fluid is used?
3. Does the same fluid go back to the rear and axles? I have a small leak in one axle and just want to make sure this is full. I will be repairing this shortly and just want to be safe.
Any Help on this would be great.
Thank you.
Scott
   / L345DT Transmission Question #2
Thank you.
Scott
There should be a "dipstick" behind your right foot when you are sitting on the seat to check the trans. level.
Ok got it. Now. Where should the level be on the stick? Also what weight gear lube? Just 90w?
Thanks!
   / L345DT Transmission Question #4
Thanks!
There should be a full mark about an inch up the stick. The rear axle and transmission case is the hydraulic reservoir so it uses universal tractor hydraulic fluid.
Brian
There are to marks. One about a 1/4 inch from bottom of stick and the other about 1 inch up from that.
   / L345DT Transmission Question #6
The lower mark is the ADD mark and the upper mark is the FULL mark. Just like the engine oil dipstick.
Brian
   / L345DT Transmission Question #8
and if it is anything like mine, the fluid is so clean it is hard to see on the dipstick... I had to step outside in the sunlight to see it properly.
Yes...Its super clean. But it was very low. I will pick some UDT fluid up and get it back to where it needs to be.
Chevrolet C8500 Flat Bed with a Moffet Kit (A52748)
Chevrolet C8500...
Year: 2013 Make: Kia Model: Soul Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 144,857 Plate: (A51694)
Year: 2013 Make...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2008 Ford F-250 (A52748)
2008 Ford F-250...
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
2018 Jeep Grand Cherokee Multipurpose Vehicle (MPV) (A51694)
2018 Jeep Grand...
