L3450 How do I pull the fan to replace bearing?
   / L3450 How do I pull the fan to replace bearing? #1
gfs
I need to disassemble the fan shaft in order to replace the fan shaft bearing. This is for the cooling fan radiator. It looks as though it is tacked on with welding. Is it screwed on or press fit? Any suggestions? thanks,
   / L3450 How do I pull the fan to replace bearing? #3
Welcome to TBN. /forums/images/graemlins/smile.gif
You will need a Work Shop Manual (WSM) and Parts List. I took a look at the parts list for your tractor. It shows that the shaft is bolted to the fan and pump. You should be able to find a parts list for your tractor on Ebay. Here is one. Click Here
You can also contact TractorSmart They can email you a copy of the parts list and sell you the new bearing.
   / L3450 How do I pull the fan to replace bearing? #4
   / L3450 How do I pull the fan to replace bearing? #5
"Not knowing the configuration of your tractor"
In some cases it may be easiest to pull the radiator to work on the water pump.
Egon /forums/images/graemlins/grin.gif
   / L3450 How do I pull the fan to replace bearing? #6
Thanks for the advice. TractorSmart have been very good and gave me the help I needed. thanks for the link.
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2015 Nissan Pathfinder SUV (A50324)
2015 Nissan...
2008 Volkswagon Touareg (A50515)
2008 Volkswagon...
197711 (A51244)
197711 (A51244)
CFG Industrial Q.A Auger (A50121)
CFG Industrial Q.A...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
