L3400 Turning Radius
   / L3400 Turning Radius #1
digicamnut
South East Teaxs
The specs say that the TR on the L3400 is 8.2 feet with brake. Can someone explain this to me. I'm just learning.
   / L3400 Turning Radius #2
I agree that those specs can be clear as mud, and sometimes don't seem to relate to much. Lawn /garden tractors specs give the diameter of an uncut circle with a given mower size, and that seems clearer. The spec you are seeing is the turning radius of the tractor with / without brakes to the outside of the rear tire. So, in theory at least, if you turned as tight as possible on a surface you could see, you would make a circle 16.4 feet in diameter when measured to the outside tire track.
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A52705)
2012 VOLVO A40F...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
1977 Ford F-100 Ext. Cab Pickup Truck (A55788)
1977 Ford F-100...
Fiberglass Cow Statue (A55218)
Fiberglass Cow...
NEW Woods Reverse Rotation 5ft Tiller (A55218)
NEW Woods Reverse...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
