L3400 loader question
   / L3400 loader question #1
double hunter
Ford 1715
I have a L3400, 2008 model 4wd,,my question is will a la525 loader bolt onto this tractor,,the proper loader is a la463 but I have not been able to find one of these,,the 525 is designed for L2501 thru 3901 tractor,,the ounting brackets look the same,,any info will be appreciated
   / L3400 loader question #2
I doubt it would be an exact fit but it may be readily adaptable. You can probably take some measurements at the dealer if he has an L2501 and an LA525 in stock. There are also manufacturers of after market loaders such as Woods and Koyker.
   / L3400 loader question #4
I have a L3700 SU which is basically the same as your 3400. Mine has the 463 loader, and I was told at the time the 5 series loaders only difference was the curved lift arms. The mounts were the same and valve was the same. I think its rated for more lift by 100 or so lbs.
   / L3400 loader question #5
DH - The 525 should be fine according to Ansungusa.com
At least theirs does. I have it on my L3200 and it saved me a few grand over the 525.
   / L3400 loader question #6
The LA525 will fit no problem, it's the same tractor frame as my L2800 which has a LA463. It will also lift EXACTLY the same amount of weight. The only difference in the numbers is where the weight is measured from. The LA463 was measured from a more realistic location in the middle of the bucket (pretty sure) and the LA 524 (short lived) which then was turned into the LA525 which had it's lift capacity measured from the pins. It also help them make it seems like it can lift "more" but it was only a marketing thing to align with what John Deere was doing at the time.
Standard L frames have not changed since 2004... (possible even earlier but I don't know for sure...)
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
3pt 6' Box Blade (A50121)
3pt 6' Box Blade...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
